I picked up an old 618 last evening and it has me wondering just how old it is. I’ve been online searching pictures of them and the only difference I see in mine is the countershaft assembly. The setup on my lathe is bolted to the bed just under the headstock. The lathe came with a 3 and 4 jaw chuck, change gears, steady rest, a couple of wrenches, some cutter holders and what appears to be an original work lamp.
There isn't any manufacturer tags on it, either on the front of the headstock or the right end of the bed. The gear cover however has 4 small holes in a cross pattern where it looks like drive screws were once installed. I checked the right end of the ways and on the front found M421 stamped into it. Is this a serial number? I guess I’m curious about this lathe because if it was built during WW2, it may have been used in my city for the production of parts for the Hawker Hurricanes that were built here.
I'll see if my pictures load.
