I was suspecting as much. I have two of these machines and unless one takes great care in removing the handle it is easily damaged to the point that re-peening will not work and a screw into the end would be a logical alternative. That said, it also gives you the freedom to choose whatever size you want as a replacement so you could still make something work, just not as clean as the original method.
