Atlas 3966 parts needed.
Ak Coot
Feb 13, 2024
5
Hi, I recently picked up a cabinet model Atlas lathe. I believe it’s a 70’s vintage. It’s missing the tail stock handle, arbor support lock and associated parts. They are item numbers 32, part M1-47, item 33, part M6-45, item 34, part M6-44 and item 35, part 109151 in the 3996 manual.
I’m also in need of a bracket C shaft , item 34, part 041-132 on page 22 in the manual. This is the bracket with the bronze bushings that the 3/4’’ shaft that motor drives the lower pulley on. This bracket is cracked. The lathe was found in a shut down fertilizer plant so hard telling the history of how they did that.
Other than that it looks to be all there.
I would appreciate any help on this
thanks
kurt
thanks
kurt
Don't throw out the cracked bracket. Sooner or later someone out there will desperately need one and might want to take a crack at brazing it.
