Hello. My 12 inch atlas is having a strange problem with the power feed mechanism. Specifically in tuhe head stock area. Sometimes I'm can start the lathe with forward feed engaged and everything begins fine. Then in a minute or so I get this horrible screeching/rattling sound out of the headstock gears that driuve the qcgb. nothing is hot to the touch. All gears look fine.
The one thing I could think of is maybe the gears are loose and they vibrate oiut of position. I note that there is a bit of play in the gears on their shafts but it doesn't appear I can tighten it out. Any suggestions on what to look at and check?
Thanks much
Brian
Thanks much
Brian
