Hello, here is my first post.
I just bought an Atlas 12 lathe. The color is greenish but most lathes on photos I've spotted on the Web are gray.
Does anyone know the color codes and an explanation for the different colors?
They probably got a good deal on that color when they made that production run:lmao::lmao::lmao:
That is one of the nicer atlas lathes they put out, do you need any documentation for it???:thinking: I think I still have the scans of some of the docs on my other puter )
Green tends to be the correct color but what color of green is debatable. Gray is just boring.
Check the backside of one of the pieces. Likely it has not been repainted, so the original color will still be visible and not faded as it would be been protected from light.
I have the same machine, unfortunately I did not get that nice factory stand with mine. Upgrade that lantern tool post with a Phase II piston for about $150.00 and that machine will be more enjoyable to use.
Cost is one reason, However the wedge tool post holds better. Check out http://www.tools4cheap.net/products.php?cat=9 I have 2 of his a BXA and a CXA they are imports but the quality of his stuff is really good.
Thanks. A friend has one of those in the AXA size. He claims the quality is quite good apart from the small screws or bolts that he replaced with high quality ones.
I bought a piston style but was not happy with the tool being pushed down on first contact with the work. I since replaced with the wedge style and have not looked back.
