Atlas 12" (and maybe 10" ) dro mounting
Backyardmachineshop
Oct 1, 2024
7
I used little machine shops magnetic scales and touch dro, already had the set left over from a mini lathe that I gave away to a buddy.
Used a block of 1/2" x4" aluminum plate to build out the crossslide and mount the dro with the origional brackets from the kit.
This is the cleanest way I could figure out how to mount the crossslide dro to where it would function well. Ignor the center hole on the mount, that was mis-drilled
Sensor is mounted on two brass motherboard standoffs that are screwed into the carriage.
the z axis is a little rigged in but it functions perfectly . Didn't have much flat material around to make the mounting block for it.
Good job on the scales, but you might want to rethink the placement of that outlet.
That particular outlet is for my toolpost grinder and a light that doesn't get plugged in much, so the covers stay on. They have gaskets it's fiiiine
