- Jan 2, 2011
- 331
I have disassembled my headstock of my Atlas 12-36, Model 3986, in an attempt to get rid of some play/noise in the headstock. Most of the play is from the two holes in the spindle pulley that the back gear lock pin slides in. Both of those holes are wallered out oval shaped.
Here is what I am wondering about. On the spindle shaft there is a deep indent where the back gear allen screw makes contact and secures the gear. Should it be there? It seems like the back gear should be a little more to the left, but when I slide it to the left and tighten down the allen screw it forces the gear to go back to the right. Is this normal? Thanks.
