- Nov 22, 2017
- 7
Hello Everyone!
I have recently acquired an Atlas 10F Model H54 Serial 027771. Here are a few pictures of where the machine is currently located, plus a few pictures of the items that I have brought home already. Should hopefully be picking up the balance later this week. I am going to go right through this lathe, and clean up anything that requires attention. Especially the (ugly) red paint.
Note the broken cross feed wheel and reverse gear lever. These were broken when the PO moved the machine into his garage. I have the parts from the feed wheel, but not the reverse lever. Not sure if there is any way of repairing them; might have to hunt down replacements......
Here's some of the extras that I've already brought home:
2 sets of change gears.
Atlas Gears 56, 52, 48, 46, 44, 40, 36, 32, 20 - this doesn't include the ones still mounted on the lathe
Unidentified set: Bore is 16mm with a 4mm key way. 64, 60, 56, 52, 46, 44, 40, 36, 32x2, 24
1 - Atlas 6" 4 Jaw chuck with 1-1/2"-8 threads
1 - Unknown 6" 3 Jaw chuck with 1"-10 threads (this is a bolt in adapter, I might be able to machine a new adapter to fit the 10F)
1 - Cushman 5" 3 Jaw chuck mounted on a 6" backplate. Currently on the lathe. Unfortunately, I only have 5 of the 6 jaws required for a full set.
Jacobs No 75A Amature Chuck
Left, Right, and Parting tool holders.
Atlas Steady Rest.
I decided to give the tail stock a cleanup today. Sorry I dont have any good pictures of before, but here is during and after.
I have to dig through my parts bins, and find another jam nut for the feed wheel. One was missing. I used a Gr8 nut until I find one
I'll update this as I progress. I appreciate any and all feedback; especially if you notice something i've done incorrectly!
Thanks,
Aaron
Atlas Steady Rest.
Thanks,
Aaron
