- Dec 15, 2011
- 191
Greetings one and all,
I think you'll love this one. The other day I was traversing the length of the lathe bed and the traverse gear housing broke, Imagine that that wonderful ZAMAK just fell apart. I feel lucky as I just purchased an aluminum one from an eBay seller about 2 months ago just in case. So I removed the lead screw and the apron was unbolted, I then installed the new part, perfect fit ! works great. My problem now is the cross slide it turns the lead screw now which it didn't do before.
I seem to remember the same problem about 15 years ago when I cleaned and painted the lathe but I can't remember what I did to fix the problem.
This is a 10F so it does cut across the face of material in the chuck by pulling out the knob. I took the apron off about 3 times and the lead screw, looked at every thing there is no shim stock used, so a little imput would be greatly appreciated, i'm at a lose.
I feel like a total idiot.
Thanks in advance.
dgehricke
Thanks in advance.
dgehricke
