- Oct 24, 2023
- 3
Notice here so bear with me.
I picked up an atlas 10 D a few months back and while I was taking apart the traverse gearbox, I goofed up and forgot to adjust the nut on top for the preload gear I think it is? Anyways, when I kicked on the traverse selector, it broke two gears in the housing… followed by a bunch of cussing, does anyone know where I could pick up an assembly for my lathe? Everything I’m seeing on eBay is from different machines as you can see from the photos and only only need the two gears, the other two gears appear to be in good condition.
The serial number stamped on the way is KUHN D 8373 S.
Thank you,
Below is what the housing looks like with the nut on top I forgot to set, I really need a service manual for this thing I suppose.
Thank you,
