- Dec 11, 2013
- 302
My New to me Atlas 10-F lathe has a few issues.
1 - I'm very happy to say I don't have a lot invested in the lathe but want to get it working for reliable use.
Ok here are the issues:
A - The Forward/Reverse Gear box seems very loose.
The lever has a lot of slop in pretty much all directions. Left-Right and In/Out.
The directions seems almost random and there doesn't seem to be a neutral position at all.
I removed the Lead Screw and the Gear box other than being full of crap and old gooey grease I can't see any thing that would cause it to not have a neutral position.
Does the slop in this come from simply gear mesh wear?
B - The Power Cross-Feed - Doesn't feed.
Again I've removed the entire cross-slide carriage and looked at the gears and all in the back side but am not exactly sure what to look for.
If I pull the knob out it engages the gears and will cause the manual handle to turn if I rotate the gears but when in the lathe I can feel the knob pull the gears into a meshed position but nothing?
SO- I'm a little stuck and confused. I'm pretty new at these machines but not unfamiliar with rebuilding things.
I've recently restored a pair of 1972 Honda CB350 twins from the frame up. Total strip to nothing and rebuild, and have re-built MGB Motors and transmissions in the past.
I can post pic's if that will help but not sure what to take a picture of that would provide someone with a view they need to help.
Ideas anyone?
As an FYI - The entire Change Gear area was coated in nearly solid grease that looked like someone had thrown a cat in after they greased it. The grease looks like it's filled with fur. I wouldn't be at all surprised to find out it's mouse hair as the lathe was stored outside in a garage and they may have been eating the grease.
I'm currently working on just cleaning everything up so I can actually SEE the parts that are under the grease.
Ideas anyone?
