- Dec 27, 2013
- 44
When the mill head is raised or lowered, there is always a mis-alignment with the table. (round column Asian mill).
Read somewhere, that a pen lazer was used. Bought two from E bay (less than $5.) The light beam was pinpointed
thru a cap from a marker pen, #51 drill was used. A target plate was screwed to the mill base, with a #51 drill hole
in the center.Mounting holes were drilled oversize for alignment of plate with lazer beam. Works like a charm.
The second lazer is used to tease the cat.
