- Dec 27, 2016
- 45
I've been afraid to ask this question, because I'm sure it displays(pun intended) my ignorance but I've been searching for the answer here for a couple of days and I can't find a clear answer. My searching has lead me to more confusion. So here is the background and hopefully this will give someone with experience enough info to set me straight.
I bought a used Kent KTM-3vk Mill (late 80's I believe) with a DRO knowing the DRO display unit didn't work. After some attempts at testing capacitors and other parts on the display I was unable to bring it back to life. So now I'm in the market for a new DRO display. I have less then zero experience with DRO's and my shopping has lead me to the following display:
What's got me really confused is I can't tell if the displays only work with certain types of scales? the Amazon details say " Linear Scale Magnetic Scale Rotary Encoder" so at first I though that meant only Magnetic scales, but then after looking at scales. Glass scales are listed and Linear Glass Scales, and some don't even say glass just Linear Scales. Then to make matters even more confusing I found a post on here:
Which basically says they have both magnetic and glass scales working on one DRO Display just by changing the plug from the scale. I would have no problem changing the plug on my scales as I seem to have had to change plugs on just about every use machine I've ever bought (and some new ones just to get things the way I want). However I can't say the I completely understand what wires doing what so I'm sure it would result in a lot of research to mate the cables correct. But I wanted to make sure before I buy, that I shouldn't just get a kit that includes the scales:
Ultimately this is 100% a hobbyist tool so ever penny I put in I am very unlikely to get back. It does happen occasionally but very rarely, but I would really prefer to put the extra coin to materials rather than achieving that "oh so perfect setup".
Thanks for any reply's and your kindness and consideration of my ignorance. Oh also if somebody already clearly detailed this out, post that link because either I'm using words that don't make sense or the Googlizer just hates me.
Swapping Magnetic and Glass Scales
My small lathe makes it difficult to fit a glass scale on the cross slide. Therefore I was hoping to use a magnetic scale on the cross slide because of its much smaller size. I contacted DRO Pros ( an American agent for Electronica Magnetic scales) and they told me I couldn't use an Electronica...
www.hobby-machinist.com
3 Axis DRO RPM Kits, 3Axis Digital Readout Display, 3pcs Linear Scale Optical Sensor Glass Scale Ruler, 50mm~1100mm (2inch~43inch) Lathe Milling Bridgeport Drill - - Amazon.com
www.amazon.com
