- Dec 27, 2021
- 740
So, moving the tool crib at work, and dug this out, take it home they said, it's broke. Woohoo! You bet I will. The ratchet gear and pawl are missing, probably chinesium, only ID is YC on the bottom of casting. While I'm going to look for the parts, I'm not very confident. I'm thinking of machining a hex on the end of the shaft and just using a socket and 3/4 ratchet. Anyone recognize it or have a source? Other ideas? The shaft is 1.770 dia 3/8 keyway. If I go the hex route, I would like to do a minimal stock removal, on the off chance I come up with some parts, then I could put it back with the retaining collar being in contact with the hex, maybe use a longer set screw. Anyway, TIA for your opinions and advice.
