I started this machining journey by buying a used HF mini-lathe about a year ago. If it hadn't been substantially improved by the original purchaser, that might have been an exercise in frustration to drive me away from the hobby, but instead it led to me also buying his (also improved) HF mini-mill, and then to making some upgrades...
The mini-lathe came with a 4-jaw chuck, but I never used it, even when I learned the hard way that the 3-jaw isn't perfectly concentric. Last month, I used the 4-jaw on the G0709 for the first time. I started using it occasionally after that, but each time I used it, part of cleaning up for the night was putting the 3-jaw back on for next time, as the default chuck I was most likely to want.
Yesterday I had a setup already in place in the G0709, and then discovered that I needed to turn some small brass rod for the setup, so I turned to the mini-lathe. I needed very good concentricity, so I switched to the 4-jaw chuck. When I was done, I left it installed.
Today, I used the 4-jaw again on the G0709, and for the first time left it on the lathe when I cleaned up, because I felt I was just as likely to use it as another chuck for whatever I do next.
I don't think I would have gotten there without a Noga and a decent DTI though!
