Anyone need a 12 foot B&S straight edge?
Braeden P
Sep 1, 2020
1,633
Just found this thing for sale
Cant imagine hoe big of a surface plate you would need.
(edit:typo)
It would be a real b*tch to seriously use. You would need some fine adjustable crane infrastructure, and some help, and be setting about doing very serious stuff on a very big machine!
(edit:typo)
Yeah, if you can’t check it, it’s worthless. I guess somebody with an autocollimator could check it like a surface plate cert co.
Someone is giving away a free 12'x6'x18" thick surface plate on Face Book Marketplace, It
Cant imagine how big of a surface plate you would need.
would be the perfect match for that straight edge!
Just over 18,000lbs (168 lbs/cu. ft) if I figure correctly. The rigging and shipping will not be trivial.
Then there is designing and building a set of legs to support it, and hoping your concrete floor is up to the load....
Sent from my Pixel 5 using Tapatalk
Believe that I thought of several scenarios of how I could make it happen...
Personally seen a 4'x4'x8', it had a 1'x1'x8' corner taken off, Company would not tell whence it came, it was given away "free for Shipping." Pink granite also.
