Anyone know where I could get a manual for Joyal 1200WD?
O
ome
Forum Guest
Register Today
Hi Guys,
I called the company which took over Joyal in the 90's, and said there was no information about the machine.
Works well, but a manual will mKe it complete. I am willing to pay gor the manual if anyone has a copy.
Thanks,
Jon
What is a joyal 1200wd? Lets start there. Do you have any pictures? That could be very helpful.
Hi Guys,
Thanks,
Jon
Hi,
the machine is a bench spot welder
6 amp, up to 1/4 combined thickness
i will post a picture soon
thanks for any help
Jon
Hi,
thanks for any help
Jon
If anyone knows amp and time setting for thin alum sheet, thin like flashing, and then of course a manual for user instructions. Which i will gladly pay for the manual copy
Thanks,
Jon
Here are the pics, machine weighs about 80 lbs
IMG_6922.jpg IMG_6923.jpg IMG_6924.jpg IMG_6925.jpg IMG_6926.jpg IMG_6927.jpg
Did you try Ebay and Amazon? I found an owners and maint manual for my Clausing on Ebay for a good quality reproduction. I would also look into Amazon and the other book sellers site and see if one cannot be printed for you on demand. A lot of old books have been stored digitally and can be printed on demand for a very reasonable price. That is where the manual for my Clausing came from and the quality is extremely good. It is a well printed book, not a copy of a copy or anything flaky like that. Hope this helps.
Bob
That's an awesome spot welder. Aluminum is tricky stuff to spot weld. Your gonna have to clean the weld areas on both pieces with a stainless steel brush to get the oxidation off. Steel is much more forgiving. I don't have any specific reccomendations for you on time and amps. I have a cheap Harbor Freight 220v spot welder. Let me see if there are any reccommended time,-amps settings. If you dig around online, you might be able to find that info. That kind of info is non machine specific.
If i were you i would start experimenting on some pieces of steel first, to get a feel for the machine. I think aluminum is gonna be more of a challenge, and "flying blind" with aluminum is gonna present more variables into the mix that just don't exist with mild steel. When i spot weld steel on my cheapie, there's no timer involved. It's set to full blast i squeeze the 2 pieces together between the electrodes and flip on the power. Then the steel gives off a tell-tale spark once the pieces have fused together and it is done. The spark is your clue to a good weld. Forego the timer for now, you can time your sparks manually and start writing things down like amps and time it takes to spark. With this info , you should be able to get started.
Thank you for all uour advice. I am searching ebay and amazon.
Thanks
jon
