Anyone know how to run lathe gcode on a mill?
pinkpanda3310
Sep 23, 2020
93
I made a lathe accessory for my little cnc milling machine. The problem is lathe and mill have different axis orientation.
I can trick my machine into making lathe-like toolpaths but I'm having a hard time finding a usable method.
Another possibility is rewiring my machine to swap around the axis but I'd rather not be doing that every time.
Is there a way to write lathe cam / gcode with the axis reallocated?
Can't you just se a text editor to change the axis letter? Most editors can do a bulk replace. A lathe generally uses Z for length and X for diameter. How do you have your machine set up?
Now, another problem is most programs use diameter on lathes. If using CAM you need to program in radius.
Okay, a text editor can do bulk replace. I know little about text editors but I'll give it a try. You make it sound easy.
I wasn't aware of the diameter-radius difference, thank you for pointing that out. I'll do some homework during the week and see if I can do some practical next weekend.
Much appreciated Karl_T
I do something similar when using a 4rth axis - A. I draw it up using Y then swap letters. In my case, the Y axis is not used on 4rth axis work.
I think I saw a YouTuber do a mechanical version of that it was a crazy set up. He mounted a "roller" to the moving gantry and directly under the spindle so as the Y axis moved it rolled the part.
If you use the spindle as the Z axis then there is no change.
You can assign the axis in CAM, they don't have to follow the normal conventions.
I had a look but didn't find how to do that on deskproto. I might need to go to fusion 360 for this lathe cam
