Lets see CH, I'll see if I'm on the same page. This is something we do here (too many times) usually for 'one offs'. No need for heattreating. With a pile of junk stock which is "sacred", we try for a .002 taper and use the press. I want the mandrel to be sacrificial, notthe part. I'm talking about turning or threading between centers. If I am comming through, a part with a 1/2 hole, a shaft for a shortdistance is turned .002 over size then we turn that to a taper back to .500 and press it. I advise using alum for the mandrel, becausewe are not about to hog cuts like .500; we are only dealing with light cuts and alum will not damage the part. Then after, its put backin the stock pile. In fact I'm am doing so this week with a new improved engine cam bearing remover and installer that I plan to machine forNapa for resale. And those go for $100+ I can for $50 Our old school local mom & pop Napa allows this. So try and keep no more than.002 or .0015-6-7 or so...over a snug fit..."turning between centers rules"
