I run mine at a higher pressure to account for some pressure drop when in use, you also need to fully depress the buttons otherwise the air flow is not sufficient, and yes they eat a lot of air. I am running an 80 gallon 2 stage compressor, so has not been an issue as to air supply. Prior to that I had a smaller high pressure Dewalt, it would cycle fairly frequently and the noise drove me nuts.
I have had issues with the drawbar supplied and the engagement as well as it rattling. The drawbar height, mine is set at 0.050 below, recently was adjusting it and it was flush and it would not engage properly. The other issue is that at higher speed the top of the drawbar would oscillator and rattle. I just machined a new spacer at the top and used a very high viscosity grease. Make sure you also apply grease to the splines.
Last but not least, when using a power draw-bar the quill needs to be all the way up and locked, otherwise it will push down and disengage.
