I received some advice from this forum to purchase this inexpensive set of wheels for the Harbor Freight circular saw sharpener. Of course, the forum recommended the diamond wheel, which is just great. I was trying to figure out how to use the emery wheel. It says "don't grind on the side". From the instructions, the wheel can be used on either the flat or the bevel. So, I could mount it backwards and just use the flat face for grinding? Is this safe? I guess that when the wheel gets too thin, it will just chip away safely. It does look like it needs a guard, however.
