Any use for an old rusty cast iron surface plate??
DJ Bill
Mar 5, 2013
45
One of the casualties of a roof blowout in my old storage unit was a surface plate. It is an old cast iron one, probably about 2 foot square . It came out of a local high school that was eliminating its shop classes and was rusty when I got it. Now it has a nice brown layer of powdery rust on it. it has been outside and unprotected for several years now while I have been away trying to make a living on the road.
Is it worth trying to do something with this or should I just scrap it out next time I am over there? (It is at my old place 2000 miles away I get to drag stuff to Texas from once or twice a year.This year I am going to try and finish the move If I can afford it.)
My machine equipment at the house is limited to an Atlas 10F and a couple of drill presses, a 6 x 48 belt sander, and welding stuff. (I'm also pretty well equipped for jeep work including sheetmetal work. Got all sorts of hammers including the special metric ones too. :rofl:.) I can't see what sort of uses I would have for the SP besides lapping parts flat. What other stuff might a jeep guy and fledgeling lathe user use a surface plate for? ( I realize it was in the list of things that don't make you a machinist!)
You could always attach it to the roof with guy-wires or some way other to hold the roof down next time a blowout might be imminent.
:thinking:
What the heck, get some anodidzing juice and remove the rust and give ger a coat of earl and put it back in the shop, Im pretty sure a little pitting even isnt going to affect the surface that much. Or you vould use it as a bucking table for sheet metal or knife forging too. As soon as you get rid of it you will find a use for it that you haven't considered, always happens to me when I get rid of anything.
Bob
Sounds life a flat grill to me. Umm flapjacks and bacon.:ideas:
*******Just Saying*************Gator*************
A cast iron surface plate can always be useful. you could even have it Blanchard ground...
JOHN
I think I would also keep the SP. I have a cast iron SP also. I haven't used it yet, but I think it has possibilities.
if you're real careful, you can use a plate of glass with 100 grit sandpaper glued to it to create a flat surface.
invert the cast iron plate on your newly constructed surface polisher, and make small pushing and pulling motions from all sides.
with a little sweat you can remove the rust and take out high spots pretty quickly, due to the weight of the plate.
good luck!
While a surface plate is on that list of things that "won't make you a machinist", they are useful tools. I think with a little cleanup you could get it back in to shape.
A solid 2 foot square work surface will be useful even if not perfectly flat. I vote for the 're-grind'. Even if it fails, the plate will be a good assembly spot if nothing else.
I use an old cast iron table saw top for a welding table. Iron is good stuff.
Hey everyone,
We have another Professional Machine Rebuilder...SideCar580. He is very famous as one of the best Bridgeport rebuilder in the country. Lets all welcome him to the forum.
Thanks again John for joining!
Rich
