+ 1 on the miter gear nut, easy to check, just take out the screws from lead screw bearing at the r/h end of the bed then pull out the lead screw, after checking the half-nuts are open.
The apron can then be dropped off after removing the two screws or socket head bolts in the top of the carriage, it may need a tap with a soft hammer as there are locating pins that can be tight.
If there is a problem you can remove the gear and use the lathe but without a powered cross feed.
Bernard
