- Jun 12, 2018
- 724
I was using a 1/2" cobalt roughing endmill to slot a piece of 1018 steel with a .070 depth of cut. I have a PM-25MV, locked the Z and X axis.
I was pushing the workpiece towards the endmill and the vibration was really bad. I was feeding in pretty slow at 1200 RPM.
Is slotting in generally something you don't do? I decided to start cutting in the middle of the workpiece instead of the side like I normally do, doing conventional milling.
The endmill became red hot and something moved, not sure what. The endmill ended up going up, and the workpiece has a sloped cut instead of straight. Ruined it.
Any advice?
Any advice?
