I saw somewhere a man threading on a lathe and at the end of a threading pass, the carriage was disengaged as normal, then the man pulled a lever on the tool holder which retracted the threading tool enough to be able to then crank the carriage back to the starting position. Then lever on the tool was then pushed fwd. To return the threading tool tip to the previous position. Then the cross slide would be advanced as normal to the next depth pass. This seemed so cool. Has anyone ever seen any plans to build this type of tol holder? I presume it was a gear rack and gear set up or some type of eccentric boss set up to advance and retract the tool.
Bob
Bob
