- Dec 6, 2012
- 2,708
I'm working on a Pratt Whitney 12x30C lathe.
Bed was in good condition, cross slide and compound were a mess.
Cross Slide rebuild came together nicely.
Am now working on the compound. I figured I needed to make a new compound feed screw and nut. However, todays preliminary results showed that the new nut moved backlash from .080 to less than .010 and I'm good with that. This weekend I hope to have final fit up and scraping of the compound flat, tails and gib. Will see if the .010 improves....
Anyway, I thought I'd show pics of the anti-backlash compound feed screw nut I made.
The new nut is as large as I could make it inside the cavity of the compound as I needed to add the two set screws and jam screws.
I've not made an anti-backlash nut before. Spoke with my mentor (Danich) and read some stuff.
My only point in this post is that anyone can do good work, have fun and be safe.
If you've got a backlash problem, you might likely be able to repair your problem without significant expenditures/purchases.
Daryl
MN
Daryl
MN
