O.K. This is what I needed it for, I guess I should have been more descriptive. This may get overlong. First, I inadvertently destroyed the serial cable that came with my E Bay Chinese 4 axis controller card. So, I had already built a customized case to fit all the components, neat and sweet, and I didn't want to re do it again. Anyhow, the jumper as I call it, will connect the printer cable from the back panel to the controller card. I wanted a db25 male, female, ribbon wire cable 18 inches long but, could not seen to find one online, I am the worst web searcher ever !.
So, what I did was go to Radio Shack, bought some crimp connectors, wired up a cable of black and white paired wires from the male to the female number to number with on extra black wire for #25. So, whatever signal travels through #1 pin should flow right through as usual, right?. My thinking is that what flow thru at pin #1 will follow the wire right thru to the computer as if it was connected directly. So, that's what I did to solve the issue, but, I have not tried it under power. I am not quite done building my system yet.:bitingnails:
