I recently bought a Matweld MIG 250Y machine: http://www.arcwelders.co.za/matweld-mig-250y-multi-process-mig-tig-mma-welder/
I've been doing normal arc welding for years, fixing things on the farm, but this is my first MIG.
I realize that this machine is not in the league of the bigger brand names like Miller, etc, but I reckon it's good enough for what I intend to use it for.
On my machine, there are adjustable controls for Amps, Volts, WFS and Pulse control.
A friend of mine, who happens to have an identical machine, apart from his machine not having the pulse control, advised me that I can turn the Amp setting to zero while doing MIG welding. According to him, only the Volt setting is used with MIG, while the Amp setting is only used when doing normal stick welding.
I did this and I actually didn't realize any difference between the initial 180 odd Amp setting and 0, while doing MIG welding. However, on the Miller app, and in just about all other sources that I've read, an Amp setting is given, together with the normal Volt and WFS settings, when determining machine settings for a specific metal thickness?
I would appreciate some opinions and advice on this, please.
