So I know there are hundreds if not thousands of threads and videos on tramming, but I have yet to find an answer to my question.
I have a precision matthews PM-25MV and I'm trying to tram the head. I have both a spindle square, as well as several indicators and arms to choose from. And I am aware of the typical process of setting up the square (or indicator), zeroing, sweeping side to side and adjusting the head as needed. But what I have never seen, or found in any reference, is adjusting Z-axis height and checking tram at a different height. Does anybody do this, or does everybody just assume if the tram is good at one place it's good throughout Z-travel? In theory, if your column is straight and square to the table, it SHOULD be good throughout Z-travel. Even if the column isn't square to the table, by squaring the head to the table it should stay square to the table, but translate slightly in X.
However, what I see is if I tram with the head as close to the table as possible, then raise Z ~8" (as far as my indicator arm will reach without reducing the swing radius), then tram is out ~0.004". After several attempts I finally raised Z ~4" (1/2 the available travel), and trammed there. Now when I move Z back to the low point, It's a little over 0.002" out, with it indicating that the head is rotated slightly counterclockwise. And when I move Z to the top, it's 0.002" out with it indicating that the head is rotated slightly clockwise. This matches the ~0.004" variation from high to low, and it appears as if the head is moving in an arc with the center point of that arc somewhere in space to the right side of the machine.
Throughout this entire process I have had both X and Y axes locked in place without moving them. And I lock Z at every position while tramming. I have also checked for play in the Z-axis gib, at all 3 locations mentioned above, and it's solid. I trammed first with the spindle square, but it only works with the head close to the table. Then swapped to the indicator on the arm to verify without moving Z, then moved Z. I continued to use the indicator for all following measurements.
I don't have any machinist squares (but have them ordered), so I haven't checked if the column is square to the table. And it seems to be out of tram in Y as well, but I haven't paid enough attention to see how far out it is. Shims are also on order.
Based on the above, here are my questions:
1. does anybody bother checking tram at different Z heights, or just assume it's good?
2. am I overthinking it by checking at different Z heights?
3. does my process seem sound, or am I possibly making a mistake which is distorting the measurements or giving me false readings?
4. If my process seems sound, and my measurements seem accurate, does my conclusion that the head is moving in an arc sound plausible/reasonable?
5. If my conclusion is plausible/reasonable, what are the possible causes? With no play in the gib, is it reasonable then to assume the column way was somehow ground in an arc?
6. If the column was made wrong, is there any simple solution that wouldn't require complete disassembly and re-grinding or scraping the way?
7. Am I overthinking this entire thing?
I'm sure there are many here with far more knowledge and experience than me, and I look forward to hearing your thoughts. Thanks!
