- Jul 29, 2014
- 2,847
Somebody inspired me with a spinning magnet degausser design, so I made a very simple and effective degausser. My rare earth magnets were about a half inch in diameter, and I had a scrap piece of ABS about 1.5” diameter and 0.8“ thick. I plunged four half inch holes down to 0.020 short of penetration, and pressed the magnets down to the bottom. Alternating poles of course. Then I had a 1/2” rod of more or less the same material, and parted off four plugs, and pressed them in to hold the magnets.
I can in a jiffy chuck this in the 3 jaw, spin it at maybe 500 rpm, magnets facing out on the thin side, and just pass the material by, as any degausser. It does a fine job, took 20 minutes, and was amusing.
By the way, I am pretty much full converted over to the KWIK-SWITCH style tool holders. I have the feeling these are little known, and the way they are marketed that’s not going to change much. But man, I just load up some holders with the common tools…edge finder, spotting drill, half inch carbide end mill, 1.5” end mill for facing, tap guide, Indicator holder, those are always ready, and 3 Jacobs chucks that I load with the drills needed for the particular project, say, a tap drill, body drill and countersink…and man, click click click you’re done. No swapping R8 collets involved.
