Hi everyone I was able to buy a Birmingham mill with a 3hp. motor. According to the owner and by the looks of the machine it was only used twice by his brother. This mill sat in a open front barn exposed to lots of dust since 2006. While I am still in the process of cleaning it up everything has as it should except for the quill down feed. The problem That I have is the only way the the down feed will work is if I hold the engagement lever out if I let it go it springs back in and the power feed stops. It will not stay engagued on its own. I don't see anything broken and I have sprayed everything down with penetrating oil but so far nothing as worked. Any advise would be greatly appreciated.
