Hi All
One thing I am getting out of my other thread here is that I will be better off using HSS instead of these carbide things I got with the purchase of the new lathe.
They cut well but not shiny clean. I have found that the LMS HSS parting off tool has a much cleaner cut than the insert tools.
So I am going to switch to HSS. From what I have learned, M2 HSS is what I should go after.
Some questions:
3/8" or 1/2" for my 9x19 lathe?
Is there a pre-ground set that I can trust in? I read the reviews on Accusize and a lot of reviewers said the bits dulled quickly in mild steel.
I would consider blanks but I am skeptical about two things; my small Lowes grinder and my skill set at grinding a quality tool.
Your thoughts?
Lastly, how much should I expect to pay for a quality set if I go that route? Let's say 5 pieces, left and right turning, parting off, outter and inner threading.
Some questions:
Your thoughts?
