4
4GSR
Forum Guest
Register Today
I did not find a specific catagory to put my post so here it is in the general projects. Tony, feel free to move it to a proper catagory if necessary.
I've built two other jib cranes for use in my shop a few years back. There's pictures of them on both this site and the other web site out there, too. Their probably posted on several sites out there by now. No biggie to me. I may get upset if someone starts building them for profit, I hope not.
My third one is a little bit larger spand with a heavier lift of 500 lbs. My other two are limited to 300 lbs lift. This one I built to handle all of the heavy stuff on the rebuilding of my 20" Lodge & shiply lathe. I need something to handle the tailstock base for scraping and fitting, along as the carriage, taper attachment, as well as changing out the chucks on the lathe. Once the lathe is running use it to load material into the machine.
Here's are a few pictures of process of my third one. Enjoy!
Drilling holes for mounting bolts in vertical member.
Finished parts waiting for assembly
During assembly and fitting of the tie rod, the tie rod interferes with the garage door opener. Easy fix, raised the door opener up just enough for the tie rod to clear, barely by .001"
Foot mount on the floor.
Finished jib crane. I proof tested it picking up the tailstock for my 20" Lodge & Shiply lathe!
Oh, the Dr Pepper theormeter is not for sale, don't even ask!:biggrin:
