Annealing just a section of a arbor ?
Alcap
H-M Supporter - Gold Member
Apr 16, 2019
746
I asked this question in another thread about draw-bar thread size but maybe better it's own thread . I have a 2MT arbor with metric threads I would like to anneal just the threaded end , drill and tap for a 3/8-16 Heilcoil insert . or a threaded plug fitted and brazed on . Can just the end be annealed for doing this ?
An old back Smith operation would be to heat the area of a part to be annealed red hot and then slowed to cool slowly in a bucket of wood ash or other non flammable material. Should work in this operation,but check with a file before machining . Will not work with air hardening or high speed steel.
I don't see why you couldn't immerse the sensitive end of the part in a bucket of water and heat just the threaded end. I'd be somewhat surprised if the threaded end is hardened at all.
I think I would also consider how important the arbour and the trueness of it is. Any time you heat something to annealing temperature and cool it there’s a risk of warping the part a little. On an arbour where you want it to be really true, it might not be something you want to mess around with.
-frank
definitely do not use a heli-coil insert because they do not work good for more than single time use, and you would have a real problem if your drawbar seized in the MT2
Dave
Warping is definitely a risk if you bring the piece up to critical temperature. If you need to use heat, try a sub-critical anneal. No need to take it all the way to non-magnetic. Just a very dull red is great for medium carbon steel. Even better, heat slowly and evenly. A propane torch is better than an oxy-fuel torch in this regard. Barely any color is good, else you run the risk of heat straightening, and this would not be straightening.
My mill uses a self-release drawbar ,there's cap on top which is held in place with 2 set screws . I kind of like that feature so it's a little more involved to swap back and forth
