- May 7, 2014
- 776
Morning Everyone! Still digging into the new Mill on A36 which cuts like a dream on this 30taper. So now the basics are done, the Axes in 1045 flame cut (plasma) are next. We'll grind down the edges and scale beforehand. The 1045 is pretty tough. The Carbides are expensive and we're wondering if we should consider Annealing first? I know I've covered the 1045 Milling Q's in past posts early on last fall. Put we have a old furnace someone gave us. It needs an element and a controller. We're wondering if you think it's worth annealing before Milling then re-harden after?
ALLOY INFORMATION FOR AISI 1045 CARBON STEEL
CHEMICAL ANALYSIS
C Carbon 0.43 – 0.50
Mn Manganese 0.60 – 0.90 max
P Phosphorus 0.04 max
S Sulfur 0.50 max
GENERAL CHARACTERISTICS
C1045 is a medium carbon, medium tensile steel supplied as forged or normalized. This steel shows good strength, toughness and wear resistance. C1045 will through harden to 2.5” (63mm) with a tensile strength of 66 – 120 Ksi (620 – 850 MPa).
C1045 is a versatile medium carbon engineering steel that can be through hardened to about 2.5” (63mm), as well as being flame or induction hardened to Rc58. The steel can be readily welded and machined providing correct procedures are followed.
APPLICATIONS OF AISI 1045
This grade of steel is used for axles, bolts, forged connecting rods, crankshafts, torsion bars, light gears, guide rods etc.
FORGING AISI 1045 CARBON STEEL
C1045 is forged from 2100 – 2300 º F (1150 – 1280 º C) down to a temperature in the range1600 – 1700 º F (870 – 925 º C.). The actual forging and finishing temperatures will depend on a number of factors, including overall reduction during forging and complexity of part being forged. Experience alone will determine near exact values for these two parameters. Parts are air cooled after forging.
HEAT TREATMENT
Heat treatment is carried out on this grade to render it suitable for machining and to impart to it specified mechanical properties.
ANNEALING
Full annealing of small C1045 forgings is carried out between 1450 and 1600 º F (790 – 870 º C) followed by furnace cooling at 50 º F (10 º C) per hour, to 1200 º F (650 º C) and air cooling.
NORMALIZING
The normalizing temperature range for this grade is typically 1550 – 1600 º F (840 – 870 º C,) Normalizing is followed by cooling in still air. When forgings are normalized before hardening and tempering or other heat treatment, the upper range of the normalizing temperature is used. When normalizing is the final treatment, the lower temperature range is used.
HARDENING
Hardening of this grade is carried out from an austenitizing temperature of 1510 – 1580 º F (820 – 860 º C) and oil or water quenching.
Flame and induction hardening may be carried out by heating quickly to the desired case depth and quenching in water or oil. This should be followed by a tempering treatment at 300 – 400 º F (150 – 200 º C) to reduce stresses in the case without affecting its hardness. A surface hardness of Rc 58 may be obtained by this treatment.
TEMPERING
Tempering after normal hardening and oil or water quenching is carried out at 750 – 1260 º F (400 – 680 º C) to give the required mechanical properties as determined by practical experience.
MACHINABILITY
Machinability of C1045 is good providing the full annealing cycle described above is used, ensuring a coarse lamellar pearlite to coarse spheroidite microstructure.
CHEMICAL ANALYSIS
S Sulfur 0.50 max
HEAT TREATMENT
ANNEALING
NORMALIZING
HARDENING
TEMPERING
MACHINABILITY
