Anilam Crusader Post Processor
Sierevello
Jun 24, 2014
11
Does anyone have a working post processor for an Anilam Crusader M 3 Axis Mill?
Thank You,
Steve
For what CAM program? The post processors are all specific to whatever CAM program you are using.
Jim... Right now I am using HSMexpress but I am open to anything I can get a working post on.
Thank You for your help!
-Steve
The HSM post is a bit of a pain to edit, but as I recall the Anilam post is pretty much like a Fanuc post. You might try that and see what happens.
What I would do is enter a short program in the Anilam using the manual input, then look at the G code in the editor. Compare that with the output from HSM. Then just edit the post processor to get the output format you want to run the Anilam. A bit of a pain, but you only have to do it once.:)
