Good morning all,
I am hoping someone out there has a little Anilam programing experience. Here we go: I have a 1 inch piece of aluminum bar between centers. I get to why in a few. I would like the milling machine to increment into the -Y direction for machining the profile. My plan is to machine the geometry inboard, than rotating the piece 180 degrees and run the program again to complete the other side. It is a mirror image. Currently the Mill cycle is incrementing the profile in the -Z direction, like normal milling.
Any words would be appreciated. The machine is a factory produced Bridgeport 3 axis with a 3000M controller.
Thank you.
Thank you.
