- Dec 31, 2010
- 937
First use of angling angle plate so found 2 of the 3 "T" slots would not accept 0.5000" bolts which has led to a general check-out. After tramming in one machined face I found the distance to the operators side of the first groove from the machined face varied by 0.022" using a dial caliper. The plate is 7" X 10" so being sure the 2 machined faces are parallel will be the next check. It is cast iron and rotates very smoothly.
I am going to try to get to get the groves parallel to one of the machined side faces and as close to 0.05000" as possible. Obviously the angle plate will have to be mounted on the mill table with 0" run-out to get this done. Any helpful suggestions on getting this angle plate trued up will be appreciated.
Have a good day
Rock breaker
Have a good day
Rock breaker
