- Jan 16, 2017
- 216
Hey Guys
My question is regarding milling the angles within .02. We have to mill these, then they are getting sent away for hardening , then we have to grind them. I need help on milling the correct angle at this point. After I drill the holes for both angle plates then cut it in the middle with the bandsaw, how do I get the desired angle milling it? Do I put two other angle plates that hold my piece flush to the top with a 60 degree angle? Like I'd have one 30 degree on one side and something flat on the other side then clamp them in the vice jaw? Attached picture of blueprints. THANK YOU!!! You guys have been awesome.
View media item 95791
