- Jun 8, 2016
- 640
I hope I can say this correctly, or at least say it so that they way I understand it makes sense and can ask my question.
Regarding a metal lathe;
I understand that the saddle only moves in the linear direction of the length of the material relative to the work. Also, the cross slide moves at 90* to the work.
The compound however can be set at any angle relative to the work. And on top of the compound the tool holder can rotate.
So, I see that the compound is 'routinely' set at 29.5 or 30 degrees. Does that mean that the tool holder is also at that angle? Or is the tool holder and therefore the cutting bit always set at 90* relative to the work?
Does that make sense?
