10HP VFDs are pretty inexpensive as well. I got one of the ebay ones for ~$270, and it has been working great! Additionally, you can run a bigger motor on a smaller VFD, but it will over-amp when the motor hits that required HP. For example, mine is a 15HP motor off a 10 HP motor.
I found a link to a manual, and got here: https://industrialmanuals.com/toolm...he-technical-servicing-manual-year-p-2553.php
A little cheaper, but from the UK https://store.lathes.co.uk/print/ma643
I just googled TUE-40 lathe and found a couple of discussions on it.
No. We have single phase 230V here as well and I just bought a 5hp VFD, so they are out there.The problem I have with VFDs is that I have a single phase 230V supply and the max power VFD from 1ph to 3ph is 3HP
I don't believe thats true... I also run single phase 230v on both a 5HP surface grinder (that REALLY needs the 5HP) and the 15 HP lathe (on a 10HP VFD) that I have definitely cut more than a 3 HP motor can do...The problem I have with VFDs is that I have a single phase 230V supply and the max power VFD from 1ph to 3ph is 3HP
