- Feb 1, 2015
- 10,025
When I drill into a sensitive enclosure, I liberally coat the drill with thick grease and clean the flutes out regularly. The chips will stick to the grease rather than fall into the enclosure. You can also magnetize the drill to prevent the chips from straying. The same procedure works for the tap.Finally, mounted the motor and set up the belt! Had to machine off the bosses. 5 out of 6 tacks had good penetration.
That motor will be staying put.
Next is the encoder mounting. Peeled off the front panel to see what was behind it. All the electronics of the lathe. However, if I put something there, like a plastic sheet, the drill chips shouldn't bother it.
