@RJSakowski, I have a couple of questions on your implementation of ELS. I am referring to this picture. Didn't want to ask in the epic ELS thread, where this picture was found.
What is the thickness of the motor mounting plate? Is this to make up some of the lead screw offset? Did you hog out the casting to at least 60 x 60mm for the motor? It looks like it, at least based from the photo. How did you do that, just a file? What width is the belt?
I've been trying to find pulleys that work out making up the difference in offset between the motor and the lead screw, and haven't found that many choices. A thicker plate might work better than what I was entertaining.
Using a timing belt for the encoder, that looks pretty nice. I was thinking of using a module 1 60T gear where the pulley is, and a module 1 40T gear on the encoder, which should get me back to 1:1 on the spindle. Of course that makes the mounting a little tricky, but I think it is doable. The belt is probably more forgiving.
