- Jan 1, 2022
- 19
I'm posting to get a head check on what I want and if I'm thinking about it the right way:
Overall, I'm looking at a benchtop CNC mill, something about the size of a PM-25. I've done some research and realized there's quite a bit of overlap with the concepts of a 3D Printer (which is basically a CNC hot glue gun).
What I think I'd like to end up with is a small CNC mill that I can also use in sort of manual mode.
On the electronics side, it looks like motor, drivers, a controller, and a computer. The computer interprets the g-code, sending pulses to the controller which then uses the drivers to rotate the motors a specific distance.
Comparing this to a non-CNC mill, the computer and its monitor can serve as a DRO, right? Do folks use CNC machines this way? Are MPG pendants used to control are would I continue to use the wheels on the mill?
Also, historical posts make me thing CPU power was a problem in the past, is that still problem given modern PC hardware? I'm assuming CNC controllers no longer use parallel port connections, and USB is fast enough? For comparison, on one of my 3D printers, the "PC" is a Raspberry Pi4, and it is capable of controlling 7 stepper motors (4 motors for Z, 2 for X/Y, 1 for the extruder) without breaking a sweat.
