I have really been enjoying my new hobby. Just finished a set of v blocks (not to nearly the tolerances of the youtube video stars, but I'm pleased) and hope to harden them tomorrow. Today I started my next project a fly cutter. I cut too much off my blank and needed to trim off a 1/4". I figured since I already had it in my lathe I would just part it off. It is 2" round steel. I sharpen the tool, hone it, make sure it is dead on center and perpendicular to the piece and all I get is chatter and fine little shavings coming off. I slowed my speed down with my back gears to around 160 and used oil. Any advice? My next project may be a tool post grinder so I can put a cut off wheel in it!!!!
Parting can be one of the biggest challenges on a lathe... the smaller and less rigid the machine the worse it gets. There are a lot of variables at work here, so I'm just going to throw out some random thoughts. Sometimes, little twists can make a big difference. YMMV depending on your setup, equipment, material, experience, etc..
1- This is a big one here. If I only needed to remove 1/4" I would not have parted it off... I would have just faced it off. Much safer and in the long run, much quicker. Or, since it was 2" diameter, if I had more to remove that 1/4" I most likely would have taken it off and put it on my band saw. For me parting small diameters is pretty easy/safe, but larger diameters, especially on smaller lathes, I would only part as a last resort.
2- I usually will have my parting tool above center to help keep the work piece from climbing over the top and breaking my tool. As you get closer to center the tool will stop cutting because it is too high and at that point I will back the tool out, lower it down a little and continue parting doing this at many times as it takes. You can tell when it stops cutting because you will feel it while hand feeding.
3- I've had my best results will only grinding ~5 degree clearance on my HSS parting tools. More seems to cause more chatter.
4- Part as close to the chuck as possible. If out a ways, lightly put a center in the end if you can. Don't apply much pressure or, if you do, back it off before you break through. This will help stabilize and help keep the part from climbing over you parting tool and breaking it.
5- Keep you parting tool as short as possible. On deep parts start with it out only a small amount and stop when you run out of length and lengthen your tool. The shorter you can keep it as you go, the better.
6- Use a good grade of cutting oil. Don't be bashful with it.... slop it on good. You want those chips to flow out easily and not get hung up. If they do, you're in trouble.
7- Here's a tricky part... sometimes when you get chatter you have to feed in harder to get a good chip started and stop the chatter. Of course if you feed in too hard you're in trouble. This can only be learned by experience and it is still a risky maneuver. It takes some finesse!
8- Run the lathe as fast as you can without chatter and from burning up your cutting tool. If you run it very slowly, and sometimes you just have to, it can be very difficult to feed it in by hand at a nice, gradual, steady pace. It's very easy to feed too fast and then you're in trouble.
9- Make sure your tool is exactly perpendicular to your work.
10- I usually grind my tool at an angle so the piece drops off leaving the burr on my stock. But, this angled grind can cause the tool to want to walk off sideways so only use a very slight angle or none at all.
11- The narrower the blade, then less likely to chatter. But, the more likely to break because it is weaker.
12- Lock your carriage in place.
13- Take the slop out of your compound slide.
There's my 5 minute brain dump!
Did you notice how many times I said you could get into trouble?
YMMV and I'm sure others have suggestions and may very well disagree with some of what I've said, but these are things that I have tried over the years with some success.
Good luck,
Ted
