I bought a low hours used pm940 a while ago as my first mill. I am trying to use a shars carbide insert end mill and fresh inserts. I've locked the non moving axis' and the quill. the tool says 3000 rpm and a very aggressive cut something like 30ipm I don't remember the exact specs off the top of my head. I was trying high speed and building up feed of cut but I am getting a lot of vibration before I get anywhere near the recommendation. I have no cooling if that matters .4 depth on the z axis and .1 on the y axis in 1018 cold rolled bar stock. And maybe 2 ipm across the x axis but the machine is vibrating enough to move a wrench and my calipers across the table. Am I expecting too much of this machine to be able to handle a cut like this? I'm not talking the 30 ipm just the vibration. I went with the carbide because of some hard material I had to work on that ate up my 3/4" hss end milk that didn't justify eating. Seeing the machine vibrating has me nervous to turn up the rate of feed. Chips are small but coming off darker.
