- Oct 23, 2023
- 15
Hi All,
I have an Atlas H54 lathe that I picked up last fall. Between having to reorganize my shop to find a spot for the lathe, the holidays and other things going on that get in the way, I have not really done much with it other than get it moved into its place in the shop. Well yesterday, I decided to use it for the first time to help make a part for my race car project that I have going on. There looks to be an issue with the tool post setting about 1" too high on the compound. I have looked it over and I do not see any way to adjust it down enough to get it to line up with the work piece. The tailstock and headstock align up and centerline of both measure just over 5" up from the ways so that looks OK. I am wondering if the compound on the lathe could be for a 12" lathe. I looked on line and found a couple of photos of what are listed as 10" compounds and they do look to be a bit different than how mine looks. I do not know enough about the Atlas lathes to know if it is possible to put a 12" compound on a 10" lathe but I do know that there are a lot of common parts on the two different sizes so maybe that is possible. If someone has a 10" lathe out there, a quick measurement from the ways to the top side of the compound tool post mounting would be great.
This is interesting if this is the case as the compound that is on the lathe looks like it has been on the machine for a long time and I would assume has been used with the machine (on a 70 year old machine who knows what kind of mix matching could have been done). The guy that I got the lathe from had never used it other than to plug it in to see if it ran and there is no way to trace it back to who would have been the last person to turn parts on it. Looking for opinions on how to tell for sure that this is a 12" compound (if that is my problem) and if anyone has some ideas on a good way to be able to use the lathe. I have no issue with getting a different compound for it, I just want to be sure that I get the correct one. I am thinking about getting a quick-change tool post for it so maybe this could be an option to help get it to work. I have attached a few photos.
Thanks,
Kim Barron
Thanks,
Kim Barron
