- Aug 29, 2019
- 712
I've been trying to re bore a hole in my apron today. Kept trying to take .010 DOC and when I would start to bore it was trying to take .125 DOC. Finally, I realized the boring head was loose in the spindle bore. This was caused by a variance between the length of the threads on the draw bar and the threads inside the R-8 arbor. I solved the problem by machining a quick spacer to take up the slack and now itis cutting on target. I've been seeing the same thing with a set of R-8 collets that came with the mill and also bought a complete set of R-8 new collets and same problem. the spacer will take care of the problem on all of them, but it is damn sad that a precision tool is not standard. All R-8 should fit all draw bars etc. Some of the tools from China are M-12 thread but R-8 taper. I got the problem fixed but should not have to spend valuable time correcting problems of this kind. It is not just this mill or this draw bar PM 833-T states in the manual that some tools will require a spacer.
