So I have a really big job coming up from a pipe fitter friends company. They need 38 blind flanges drilled and tapped with a 1/2npt test port. This is how they cap the ends of pipe and then pressure test their work.
So anticipating the job I ordered some tooling. While scouring flebay I found 3
1/2-14 npsi taps with a shank so I could Chuck it in a chuck for 9 dollars. Well I had bought them not looking at the fine print and being excited I found what I needed for a steal. Well receiving them I noticed the npsi not npt.
Doing alittle investigating I see npsi it is a straight pipe thread. Minimal taper. Says that you use sealant and for lower pressures. Npt doesn’t require sealant to seal and is for higher pressures. Big question is can I run the straight taper and then follow up with a npt to taper the hole. Letting the straight taps do the bulk of the work. I have 3 1/2-14 Npt taps already one with a interrupted cut which are suppose to be the catsass, two regular.
If not I’ll get back to looking for some. I just want the threads to spec and if I can use what I already have well that’s a plus. If not it was worth the try. Any experience on the matter would be appreciated thanks.
