- Dec 29, 2016
- 8
This being my first post I may as well do a short introduction.
I'm retired and living in Columbus, Ohio. My current interest is scratch building model race cars from the 1950's. I have only two machines: an Emco 9x20 lathe I bought probably 30 years ago, and one of the small generic hobby milling machine from Micro Mark a few years ago. I have mostly used them to make useful jigs and fixtures for what ever I was interested at the time. Nothing that required a great deal of accuracy, so close was good enough. Until now.
I have been wanting one of those metal band saws, the inexpensive ones from Harbor Freight and the like. I just don't have room in my basement for it. So I decided to make the power hacksaw I saw on YouTube.
It's slow, but small and perfect for what I need. It also requires much more accuracy to build than before, which brings me to my question.
I need to bore a small relief in both ends of a pipe for ball bearings to run in. The piece is 3.00 x 1.75 OD / 1.375 ID. The problem I'm having is aligning the piece in the 4 jaw chuck. I get within .002 close to the chuck, but it's way off at the outer end. I'll tap that around until it is also within .002, and then have to reset the other end. After doing this four or five times I just can't get both positions the same. How do you go about align this?
I'm using the chuck that came with the machine. The jaws are held in place by a clamping nut on the back side. Naturally any attempt to tighten them after any adjustments just throws it all off again. Do I need a better chuck? If so how much better?
Thank you.
Bill
Thank you.
Bill
